Author Topic: instrument panel light problem and solution  (Read 2426 times)
« on: September 29, 2009, 11:36:37 PM »
I ran into a situation with my turn signal indicator lights not working ever since I got the car a month and a half ago.  I thought the problem might be in the circuit panel that is on the back of the cluster.  Instead I found that some of the sockets were damaged and missing a contact on one side.  I bent the bulb wire over to the other side and voila!  I now have turn signal indicators again!
If you are having problems with instrument lights not working, check the sockets and you might find that this is the source of your problem.
burk17
  • Mustang: 1966 Coupe
Re: instrument panel light problem and solution
« Reply #1 on: September 30, 2009, 10:23:21 AM »
Good catch Jeff. It's a good thing to check on all the lights. I've had turnsignals that did the same thing. The lube you put in the sockets is also good for your light sockets. It keeps down corrosion. Some times the fix is right in front of you. ;)
Last post June 12, 2005, 11:38:52 PM
by Jerry Baker
Last post July 21, 2009, 03:25:43 PM
Last post October 19, 2009, 05:28:08 AM
by eagle1956
Last post December 08, 2009, 05:30:40 PM
by relic1864
Last post October 24, 2011, 06:30:22 PM
by josepuebla5.0
