Author Topic: Installing Rocker Panel moldings  (Read 3348 times)
djg3582
  • Mustang: 65 mustang convertible
« on: January 09, 2010, 10:40:17 PM »
How difficult would it be to install rockerpanel moldings on a 65 mustang that never had them on before.  Any thoughts??
Thanks
Re: Installing Rocker Panel moldings
« Reply #1 on: January 10, 2010, 02:32:35 AM »
Just get the clips and screw them to the rocker panel, then use your hand to knock them into place.  A piece of cake.
« Reply #2 on: January 11, 2010, 03:10:08 PM »
Of course the screw holes will be a way for water and eventually rust to be introduced to the rockers.  If you add them, make sure and treat the holes and screws with something to prevent rust.
If there is rust there, they will help it to stay healthy and reproduce baby rust molecules in tremendous numbers.
« Reply #3 on: January 11, 2010, 06:19:28 PM »
The only 1965 Mustangs to not have rocker moldings were those with the GT option. If your 65 Mustang is an "A" or "K" code car, built after March 1965, it may be a GT. If not, a previous owner removed the mouldings and filled the holes. The easiest way to determine the latter is to look at the lower rear section of the front fender and/or the lower front section of the rear wheel well for Bondo filled mounting holes.
The next question is - why do you want to do this?
djg3582
« Reply #4 on: January 11, 2010, 09:08:48 PM »
Is not having them more desirable!
Last post October 18, 2008, 11:56:49 AM
by 66GTKFB
Last post September 30, 2009, 10:23:21 AM
by burk17
Last post November 18, 2009, 04:08:10 AM
by 69idahostang
Last post December 15, 2009, 02:17:24 AM
Last post June 06, 2011, 12:35:35 PM
by Jeff73Mach1
