Not normal
check for proper tune, that is to say proper timing good clean and properly gapped plugs, a cap and rotor and wires all in good condition and proper carburetor adjustment. I'd bet money that the problem will go away at this point. If not . . . I would check for vacuum leaks (keep in mind that your transmission has a vacuum line run to it and if the diaphragm in the vacuum modulator fails, you can have a leak there)
Before adjusting your carb, make sure you know what you are doing-I have seen lots of misadjusted carbs (more than a few of my own way back when)
