Author Topic: I can't get the fender off my 65 mustang  (Read 1342 times)
painted pony
  • Mustang: 65 coupe
« on: January 28, 2010, 02:36:44 PM »
Its free in the front and the top and bottom bolts are out in the back. It seems to be hanging up in the middle back by the door. any help? I was told there might be a bolt from the inside kick panel to the fender...
Thanks
Re: I can't get the fender off my 65 mustang
« Reply #1 on: January 28, 2010, 02:49:48 PM »
If you open the door i think there is bolt going into the fender through a bracket mounted on the side of the car.
painted pony
  • Mustang: 65 coupe
« Reply #2 on: January 28, 2010, 02:53:48 PM »
I got that one.
« Reply #3 on: January 28, 2010, 03:07:02 PM »
As I have maintained for everyone with a 64 thru 73 Mustang, get a set of the Mustang Assembly Manuals. That being said: remove the quarter panels (you may also consider removing the sill plates); there is a 5/16-18 nut with a large washer accessed thru a hole in the sheet metal - use a 1/2 inch deep wall socket with a 3 inch extension to remove.
painted pony
  • Mustang: 65 coupe
« Reply #4 on: January 28, 2010, 03:12:54 PM »
I'll go do that. Thank you Jim!
« Reply #5 on: January 28, 2010, 04:26:17 PM »
Did you get this one?
painted pony
  • Mustang: 65 coupe
« Reply #6 on: January 28, 2010, 04:49:36 PM »
yes
« Reply #7 on: January 28, 2010, 05:42:43 PM »
Have you scraped off or melted the roard tar and undercoating?
Last post March 27, 2006, 10:31:52 AM
by Russ
Last post March 05, 2010, 07:26:37 PM
by t8erchip
Last post August 30, 2009, 05:43:19 PM
by f1rstGt
Last post July 12, 2009, 03:27:39 AM
Last post July 14, 2009, 06:06:09 PM
by smileyguy4you
