« Reply #1 on: June 01, 2008, 03:09:26 AM »
1st off you have to be using a 28oz balance flexplate(flywheel for automatics) with that 351, second if the motor is bolted to the flywheel and the torque converter is bolted to the flexplate there is no way it didnt turn the pump.
either the engine or tranny installer crushed the front pump upon install
or the tv cable was nto installed at all or completely out of adjustment(controls line pressure and it will burn the tranny up if not right)
are you running the efi or a carb setup? if your running the carb setup you gonna need a lokar tv cable to hook it all together if efi you can make a trip0 to the boneyard to get the correct cable
hope this helps and welcome to the forum
