Author Topic: gas smell when idling  (Read 2452 times)
mdopro1
  • Mustang: 1968
  • Daily driver: yes
« on: January 01, 2010, 03:24:45 PM »
my car now gives out unburnt gas smell from the exhaust, specially when i start it. i recently changed my spark plugs. What can I do?
Re: gas smell when idling
« Reply #1 on: January 01, 2010, 04:12:16 PM »
You need to overhaul your carb.  It's running way too rich.
stang98
  • Guest
« Reply #2 on: January 01, 2010, 04:12:30 PM »
Check the actual filler neck. See if the O ring is dry rotted and leaking near the gas tank. I had to replace this piece on both of my stangs. Its under $20 if you do it yourself
jethat
« Reply #3 on: January 07, 2010, 01:02:33 AM »
Is the car jetted for your altitude? If you bought it from some one who had it at a lower altitude the carb need to be rejetted. Carbs also come jetted for sea level so if you high up you'll wanta re jet it.
« Reply #4 on: January 07, 2010, 01:41:43 PM »
Like I said before, overhaul the carb.
