Only thing is if you use the exhaust paint, after you clean them completely and paint them you MUST bake the paint on with an oven to stop it from burning right back off
Most of the manifold paints need to be baked at 600 degrees
I guess you would need to let the manifolds dry good befor you would put in the oven. Paint should dry pretty fast I would think. I am going for the Eastwood manifold paint. Thanks again.
