Author Topic: Engine & Tranny Swap Questions...  (Read 2632 times)
VPGould1981
  • Mustang: 1965 Coupe
« on: March 16, 2010, 07:36:22 PM »
I purchased a roller '65 coupe. I then purchased a 5.0L and T5 to put in it. Can i use the rear sump oil pan on the 5.0L or do I need to switch it with a front sump? Second, If i need to switch it, what do I do about the oil pick-up and dipstick location? Also what Tranny Mount should I use with the T-5? Thanks...
Re: Engine & Tranny Swap Questions...
« Reply #1 on: March 16, 2010, 10:56:20 PM »
Welcome -
It's a front oil pickup only. Try Mustangs Plus in Stockton, CA for advice and parts. http://www.mustangsplus.com/ I also recomend a cable actuated clutch setup which they sell.
TexasAxMan
« Reply #2 on: March 17, 2010, 09:32:24 AM »
Most any Mustang parts supplier can hook you up with what you need.
If you plan on running long tube headers, you're much better off to use the factory z-bar setup.
BlackShadow
  • Mustang: 1965 Mustang 2+2
« Reply #3 on: March 18, 2010, 02:17:25 AM »
I have tri-y long tube headers in my 65 and no problems at all with the cable actuated clutch? I think it the only way to go with the t-5 tranny it works great. Most all the mustang part houses have info and parts you need to make the updates. Installing the t-5 was one of the best thing I did to my car.  66 GTKFB  gave you a good site for info.
« Reply #4 on: March 18, 2010, 01:30:25 PM »
I agree about the cable clutch conversion.
