Author Topic: Emergency brake Question?  (Read 3693 times)
jemoore24
« on: February 07, 2009, 12:27:47 PM »
I disconnected the brake to install a floor pan. It is really tight to reconnect under the dash. Just need to reconnect the cable to the bracket. Is their a secret to reinstall? Thanks for the help! John
Re: Emergency brake Question?
« Reply #1 on: February 07, 2009, 02:59:29 PM »
What year?
« Reply #2 on: February 08, 2009, 05:56:55 AM »
Connect it at the E-brake handle under the dash, then connect it under the floor pan at the "Y"
jemoore24
« Reply #3 on: February 08, 2009, 04:54:31 PM »
It is a 1973 coupe. jemoore24
« Reply #4 on: February 09, 2009, 12:02:08 AM »
In the foot actuated assembly is a "U" shaped fitting with a round hole and a slot that the cable end with a ball fits into. The cable must be disconnected from the rear brake cables. There is a "U" shaped clip with ears that holds the cable sheath to the housing and a special clip that keeps the ball end in place.
I recomend that you get a 1973 Ford Service Manual set and a copy of the 1973 Chassis and Body Assembly Manuals available most Mustang mail order stores. As those are the only two Assembly Manuals available for 1973, you can use the 1972 Interior and Electrical manuals with about 90 pct confidence of applying to your year.
