Author Topic: emergency brake assembly for 1971-1973 mustang  (Read 3517 times)
« on: August 28, 2009, 09:45:44 PM »
Mine is no longer locking when i try to engage the brake.  as my car is a 4 speed this creates a bit of an issue at times.
I vaguely remember my 72 doing the same thing 20 years ago and I think I was able to fix it, but I can't remember how.
Are there any guides for either repair or is there a replacement assembly available?  I doubt it would be hard to make another year part work and the 1970 is available, but I don't want to rig it if I can possibly do it right.
Thanks again for any help
Re: emergency brake assembly for 1971-1973 mustang
« Reply #1 on: August 28, 2009, 10:07:00 PM »
Jeff, on my 65 there is an adjustment screw on the "Y" that is in the neighborhood of the transmission that has a nut you can turn to tighten up the cable.  If that doesn't fix it, then you may need to replace the shoes on the rear.
« Reply #2 on: August 28, 2009, 10:19:26 PM »
this problem is with the pedal assembly it pops out after being engaged as if the ratchet inside is bad.
« Reply #3 on: August 28, 2009, 10:39:48 PM »
Yeah, I had that problem too, so just replace the assembly all the way from the handle (foot pedal) to the "Y"  Mine is a pull handle, but basically the same principal.
« Reply #4 on: August 28, 2009, 11:01:54 PM »
My first car was a 72 Maverick with the pull handle and I still think that they are the coolest.
I can find the 1970 pedal assembly, but not the 71-73.  I guess i'll keep looking
« Reply #5 on: August 29, 2009, 05:32:19 AM »
Check with CJ Pony Parts.  They have what looks like what you need on page 63 of their catalog.
1-800-888-6473
« Reply #6 on: August 29, 2009, 01:26:25 PM »
I found one las night on ebay for a reasonable price.  I had looked online at CJ's but didn't see what I needed, but I did order their catalog.
« Reply #7 on: August 29, 2009, 04:42:13 PM »
Glad you got her fixed.  These old dinosaurs require constant attention.  Kinda like a good woman, huh?   ;D
« Reply #8 on: December 08, 2009, 11:41:08 AM »
Ran across this post and thought I might not have shared the rest of the story.
After looking at what it would take to swap the assemblies, I realized a lot of the dash is in the way and it would be a huge pain in the butt.
I was able, however, to slightly bend the release bar and the piece it slides through to remove some binding.  That and some compressed air made it work again.
Oh and I have a nice spare assembly now LOL
« Reply #9 on: December 08, 2009, 06:51:28 PM »
In the South, we call that...well never mind.....but it is called politely as Southern Enginering.  But, if it works, it works. ;D
« Reply #10 on: December 08, 2009, 11:57:58 PM »
I suppose southern engineering is a polite term, but what I did was to correct the fact that the part had been previously bent and was binding.  A few minutes with some adjustable wrenches and returning the parts to their proper orientation is a repair I choose to call smart rather that "southern engineering."
