Author Topic: edelbrock carbs?  (Read 2070 times)
don wilpula
edelbrock carbs?
« on: April 13, 2009, 05:25:15 PM »
I'll try this again/ Anyone using an Edlebrock carb in place of a Autolite 4100. I currently have a Pony built Autolite 1.12" on top of  Weiand-Stealth manifold...The heads are 58cc chamber, 1.9" int. 1.6" ex Lunati roller rockers Forged aluminum flat-top pistons. The heads are completely matched to intake and the exhaust are factory Hi-Po cast iron with alot of die grinding work done to them to match the heads. Ignition is an eletronic Mallory w/mechanical advance. The cam is a Crane with .498" @ .050"
I'm not fully satisfied with the Autolites performance....secondaries are slow to open... I would like to try an Edelbrock with mechanical linkage to set my preferred time of opening?
jethat
Re: edelbrock carbs?
« Reply #1 on: April 13, 2009, 08:33:44 PM »
I have an Ed 625 cfm carb and while I like somethings about it like the fact its extremly easy to work on and totally reliable I will be changing over to a Holley at some point probably this year. I'm told and have even experimented some that the Holley is much more of a performance peice. The Ed is a good carb though. They bought the carter AFB and thats exactly what it is. Been around forever.
« Reply #2 on: April 14, 2009, 12:07:02 AM »
The Motorcraft and the Edelbrock are the most reliable of all carburetors for our classic Mustangs.  Bar none.
