Author Topic: Dash Light problem in a 73 Mach 1  (Read 2489 times)
« on: November 21, 2010, 09:03:37 PM »
For starters, this is likely a problem I created :(
I installed a stereo, and when I went to drive the car tonight I had no dash lights.
For full time power to the stereo I tapped into a hot wire running to the clock (It is green with a red stripe.)
No fuses are blown, everything else works except the instrument lights.
I replaced the headlight switch about a year ago and have not driven it that much, just cruising and mostly during the day.
I undid all the stereo wiring and it is still the same, no instrument lights (it is set up with two plugs, the other was a two pole plug that I used for ground and switched power after checking it with a meter.
If anyone has any ideas I'd like to hear them before I take the dash back apart.
Thank you
Re: Dash Light problem in a 73 Mach 1
« Reply #1 on: November 24, 2010, 01:40:59 AM »
Found it- bad wire in the harness, likely from my wiring it up wrong.  Got it all sorted out.  Thank anyway.
josepuebla5.0
  • Mustang: 94 gt 5.0
  • Daily driver: my self
« Reply #2 on: October 24, 2011, 06:30:22 PM »
i got almost the same promblem but my tail lights are going out too nd i changed the light censor too alleardy
