Author Topic: Cowl repair problem  (Read 3214 times)
Cowl repair problem
« on: February 09, 2010, 01:32:30 AM »
So my cowl was leaking because it rusted out. Sadly no one makes a replacement for the 71-73 so i got a kit for a 65-66 and modified it to work and used a bunch of silicon to try and seal it. It slowed down the leak tremendously but there is still a small drip. Does anyone have any suggestions that i can try? I want to put my new carpet in but i can't if its still leaking! Thanks
Re: Cowl repair problem
« Reply #1 on: February 09, 2010, 07:23:16 AM »
That silicon will dry out and eventually you will have a large leak.  You need to get a mig welder and some new sheet metal and manufacture a new cowl using the existing 65 cowl that you have.   Or, you can buy used cowls from places like this.  Here is one for a 71.
http://www.usedpartslive.com/live/1/year/FORD/MUSTANG/Cowl_Panel/
« Reply #2 on: February 09, 2010, 12:56:46 PM »
I tried your link but it didn't work. As for the cowl i bought its plastic (so it won't rust again im assuming) so i used some sheet metal and that to try and seal it with some silicon adhesive that was designed to seal it so that's what i used. As for for fabricating my own i might just have to go that route if i can't figure something else out.
« Reply #3 on: February 10, 2010, 12:41:01 PM »
but more importantly, how is that engine coming along?
« Reply #4 on: February 10, 2010, 04:08:53 PM »
You said you put in a plastic one?  Do you mean the plastic hats?   I just not clicked on that link I gave you, and it works for me.  Which browser are you using?   Try it again.
« Reply #5 on: February 10, 2010, 09:01:32 PM »
Jeff: I put the engine in the car last weekend but i had to pull it back out last night to replace the fork (they sold me a 10" instead of an 11") and fix the Z bar. So the engine should be going back in the car tonight or tomorrow morning and then i should be able to run and drive the damn thing after 2 months.
Glen: It is a "cowl vent repair kit." I tried the link now and it works ill take a look at it, thanks.
« Reply #6 on: February 10, 2010, 09:27:11 PM »
Can you get a picture of the rust dangae to the cowl?  There is a 73 at the pull a part here, but I don't know if the cowl is in good condition or not (it could be worse if memory serves me right as I pulled the wiper transmission and the cowl covers.  On the 71-73 the entire cowl is beneath the hood. but if you seal the vents off, i suspect your vents in the car aren't going to work too well!
I can see if they would cut the cowl out for you to use as a patch panel, but they don't allow power tools on the yard.
Last post March 27, 2006, 10:31:52 AM
by Russ
Last post July 09, 2008, 10:48:00 PM
by Bossnutt
Last post October 29, 2008, 12:26:21 AM
by Don A
Last post August 12, 2009, 04:07:51 PM
Last post October 10, 2009, 08:27:50 AM
by FASTBACK65GT
