Author Topic: Compressor Spacers?  (Read 2070 times)
buwhite
  • Mustang: 1965 Coupe
Compressor Spacers?
« on: September 21, 2009, 06:34:30 PM »
I have a '65 Mustang Coupe, that I just bought, it's a 289 and when I look at the compressor and the belts it looks at though the compressor itself is back a little too far, is there supposed to be spacers behind the compressor to bring it forward? I think the difference is maybe 1/4" no more.
I have searched the internet all I can to find a view of how it should be but no joy, if possible, if mine needs something then I would like to have a picture of how it should be.
burk17
  • Mustang: 1966 Coupe
Re: Compressor Spacers?
« Reply #1 on: September 21, 2009, 06:41:38 PM »
I would bring it out so the belt run true. With that much offset it's not good for the belt or the shaft in your compressor.
« Reply #2 on: September 21, 2009, 07:38:41 PM »
Here is how it is supposed to line up.  I would try- to slide the compressor forward from the plate it sits on, or you have an aftermarket fan that doesn't fit.
buwhite
« Reply #3 on: September 21, 2009, 08:06:47 PM »
Fan definately seems to be fine...all that is the problem is the compressor itself. I think I definately need to move it forward toward the radiator to line up the belt. Thanks Soaring, great pictures, I don't know if you could get a picture of where the compressor bolts to the motor but that could help too.
Thanks a lot.
Brian
