I was charging it the little red trouble light glowed not really bright but it still was glowing a little. What would cause this?
Does the little red trouble light have a symbol next to it? Does that symbol look like the end of a appliance power cord? If so, that red indicator simply indicates that the charger is plugged into a household power outlet.
Another light indicator would be yellow which means a charge is in progress
Another light indicator would be green which means the charge is completed successfully.
NOTE: Most modern chargers will not charge a dead or mostly dead battery. Inside the charger there are voltage detector circuits that will not let the battery even start to charge until it detects a battery with some voltage.
To enable a "smart" charger to begin to charge a dead battery, you would have to temporarily give the charger and dead battery a voltage. This can be done exactly like jumping a dead battery in a car with jumper cables.
Proceed with that with caution.....Observe polarity. The voltage only has to be provided momentarily to enable the charger.
John
