Author Topic: Can an EFI with a throttle body use an air cleaner?  (Read 3048 times)
Nikolaeos
« on: April 23, 2008, 01:46:04 AM »
I was reading around about the pros and cons of EFI and a Carb.  I have decided, because of where I live, I would probably want to go with a performance EFI.  But I want to keep the awesome look of having an oval air cleaner on top of the intake manifold with Mustang stamped on it.  I just couldn't find clarification what it means exactly to have an EFI with a throttle body intake.  So, do throttle bodies mount a carburetor-style air cleaner, or do they also have a pipe sucking in air.  If a throttle body doesn't do that, what does?  Again, I'm talking about EFI, not Carb.
EDIT:
I may have found my answer not sure though.  I found an EFI conversion kit that looks like it can mount an air cleaner right to the manifold, but I will have to contact to be sure.  http://www.mustangsplus.com/xcart/product.php?productid=4221&cat=2700&page=1
Re: Can an EFI with a throttle body use an air cleaner?
« Reply #1 on: April 23, 2008, 01:53:53 AM »
all right there are some aftermarket kits like the edelbrock setup that mimic a look like the carb setup its pricey though http://mustangsunlimited.com/itemdy00.asp?T1=EDL3521+01
then you could also go with a factory efi setup with an aftermarket manifold and a throttle body http://www.coasthigh.com/Fuel%20Injection/spyder.htm
http://www.coasthigh.com/Fuel%20Injection/Accufab_tb.htm
i imagine this would save quite a good bit of coin since you can pick up a stock 89-93 set for a couple hundred bucks and add a few more hundred for each of those parts?
Nikolaeos
« Reply #2 on: April 23, 2008, 02:00:10 AM »
Thanks, that helps.  I hate it when I ask a questions, then go back to searching and think I found the answer and it turns out that I did.  It happens to me a bit sometimes.
« Reply #3 on: April 23, 2008, 02:22:26 AM »
yeah it works like that a lot, i dont know how long youve been into classic stangs? im only 25 but ive been messing with them since i was 15 im on my 27stang right now :P not all were classics but about half were. but i come across a lot of stuff since i read the late model books along with the classic stuff
Nikolaeos
« Reply #4 on: April 24, 2008, 11:37:28 PM »
I've been into classics since I saw them.  I have never had one though.
Last post September 13, 2008, 09:09:10 AM
by zebo87
Last post September 16, 2008, 08:14:53 AM
by crzylx
Last post October 02, 2008, 01:00:16 AM
by rmodel65
Last post November 13, 2008, 06:12:12 PM
by jot51
Last post October 11, 2009, 03:08:41 AM
by Cobra GT
