Author Topic: cam selection  (Read 4902 times)
sammywells
  • Mustang: 1965 coupe
cam selection
« on: February 10, 2009, 06:04:47 PM »
1965 289 4v mustang with t-5 and 3:55 rear gears. my question is what cam should I use. I would like a slight lope but not enough that when I hit 5th gear I have problems. Right now the engine is bone stock and It runs fine but I plan to add a performer intake but will be using the original carb and manifolds. any suggestions. thanks.
Re: cam selection
« Reply #1 on: February 10, 2009, 11:27:00 PM »
Here is a Comp Cam chart that may answer your question.  It is difficult to choose a cam for someone else's application, but if you are not going to get rid of those iron exhaust maniforlds, you are starting with the wrong upgrade.
http://www.compcams.com/Cam_Specs/Browse.aspx
sammywells
Re: cam selection
« Reply #2 on: February 11, 2009, 06:12:30 PM »
Ok, would the hipo manifolds be worth fooling with. I just hate to to the header route. I'm trying to keep things simple.
Re: cam selection
« Reply #3 on: February 11, 2009, 06:25:00 PM »
If you want to keep it simple, then keep your classic Mustang stock.  That is what I did.  I bought an 03 Mach1 for a go fast Mustang.
The K code manifolds are not much better than the C code manifolds.   Afterall, that is 44 year old technology.  Just about any header  is far superior to the old iron restrictive manifolds.  What good will it do to try to make more power with a lopy cam if you can't aspirate the engine?  It will choke itself to death.
Give Jegs or Summit a call and discuss it with them.  Here is the Jegs info.
http://www.jegs.com/webapp/wcs/stores/servlet/category_10001_10002_10605_-1_10257?s_kwcid=headers%20exhaust|2621403230
sammywells
Re: cam selection
« Reply #4 on: February 11, 2009, 08:54:52 PM »
ok, one last try. If I end up using headers what about the mid- length headers.
Re: cam selection
« Reply #5 on: February 11, 2009, 09:57:00 PM »
The longs drag on speed  bumps. the shorties don't match up real well with the pipes, and the middies don't have the catchers.  If I were you, I would stick with the stock manifolds.  Just enjoy that classic for what it is.
sammywells
Re: cam selection
« Reply #6 on: February 12, 2009, 07:20:20 PM »
thanks for the input. stock it is. do you think I should at least put a performer intake on it.
Re: cam selection
« Reply #7 on: February 12, 2009, 11:34:36 PM »
No.  If you want a hotrod, then go all out.  A performer intake manifold will do nothing for you performance-wise if you don't have the other performance additions to make that aspiration happen.  Save your money, and enjoy that classic.
