Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Contact
Login
Register
Forum
Technical forums
Topic:
C4 Transmission
Pages:
1
Go Down
Author
Topic: C4 Transmission (Read 3102 times)
Jeff1967
Photo contest winner
Mustang: 1967 convertible
Daily driver: 2011 Chev Silverado Dura Max 4X4
C4 Transmission
on:
August 16, 2009, 08:19:45 PM »
I have leak coming from around the base where the dip stick tube enters the transmission. Is there an O ring that can be replaced? If so, how hard is it to remove the tube and do it? Is there a web site that can give me help?
Thanks in advance.
Jeff
Gender:
Re: C4 Transmission
Reply #1 on:
August 16, 2009, 09:56:25 PM »
Yes, there is an 0 ring that you can replace to stop the leak.
Jeff1967
Re: C4 Transmission
Reply #2 on:
August 17, 2009, 01:57:50 PM »
Glen,
Where is the O ring at and how hard is it to replace? Also is the tube easily removed and replaced? Have you done it before??
Thanks,
Jeff
Sr. Member
Gender:
Mustang: 1971 Mach 1
Re: C4 Transmission
Reply #3 on:
August 17, 2009, 02:32:52 PM »
Im not sure if its the same on a c4 but i think the tube un-screws and then you can put the new one in and screw it back in but idk never had a c4 before.
Gender:
Re: C4 Transmission
Reply #4 on:
August 17, 2009, 03:41:17 PM »
Iit's pretty easy to change the filler tube O ring. There is one bolt that holds the tube to the rear of the motor that you have to take out and you just pull the tube up and it comes out of the tranny.
I don't know the O ring size off hand (close to an 1" though) but you can order it from one of the Mustang parts suppliers.
It fits where the tube goes into the filler hole in the transmission.
Jeff1967
Re: C4 Transmission
Reply #5 on:
August 17, 2009, 05:20:04 PM »
Thank you I will get a fill tube O ring ordered. It seems as though my tranny is leaking from the area of the shift linkage, is there a seal kit for that area as well and can it be corrected with the transmission in the car?
Jeff
Pages:
1
Go Up
Forum
Technical forums
Topic:
C4 Transmission
Navigation
Used Cars for sale
Ford Mustang classifieds
Powered by
EzPortal
