The driveshaft output shaft on the C4 is smaller than the C6 shaft, thus the old one piece driveshaft cannot be used. You'll have to get a new driveshaft made up. You'll have to have a two piece shaft made. Either way it's probably cheaper to go to the junk yard and get the ends and have the tube made up, or just take a C6 shaft with the ends left in tact and have the machine shop shorten it and balance it if needed. When I had my drive driveshaft on my Kit car custom made, it cost me about $125, but some machine shops will try to stick it to you, so shop around. Be sure to take very careful measurements as to the length.
