Author Topic: c4 transmission  (Read 7190 times)
srvblues
  • Mustang: 1967
  • Daily driver: just weekends
c4 transmission
« on: August 20, 2008, 06:23:50 PM »
I have a 67 Mustang with a 289 C4 the car won't move, the pump seems to be in good shape. the pan had grime but no metal shavings, could it be a converter? or a modulator?  any thoughts
Re: c4 tans
« Reply #1 on: August 20, 2008, 07:57:30 PM »
How do you know the pump is good?  What method did you use to check to see if the pump is still good?  Have you tightened the bands?  If you don't know let us know.  You can do it with the transmission left in the car.  Is it completely full of fluid?
Re: c4 tans
« Reply #2 on: August 21, 2008, 01:13:00 AM »
are you checking the fluid properly?? it should be parked on a level surface with the motor running in park
Re: c4 transmission
« Reply #3 on: August 21, 2008, 09:27:08 PM »
Yes, but without feedback from the original poster we don't know what the problem is and how our intervention has helped.  Damn, I get tired of answering tech problems and get no feedback from the original poster.
Re: c4 transmission
« Reply #4 on: August 22, 2008, 08:54:26 PM »
A c4 tranny is doable for the shade tree mechanic. It requires no special tools other than your regular wrenchs, sockets etc, but you will need snap ring pliers.
The kit to rebuild is decently priced, and so is the torque converter.  Just clean everything really good and go at it.  The key to a proper shifting tranny is setting the tolerances like the bands and making sure its spotless of grime during reassembly.
Re: c4 transmission
« Reply #5 on: August 23, 2008, 03:42:41 PM »
Well, it might be doable for a lot of shade tree mechanics, but they will need to do a lot of research ahead of time to know what they are getting themselves into.  Here is an article that may make up your mind whether you want to delve into overhauling it or not.
http://www.customclassictrucks.com/techarticles/0508cct_1970_ford_bronco_c4_transmission_rebuild/index.html
mustangluver
  • Mustang: 66 coupe 289
Re: c4 transmission
« Reply #6 on: September 04, 2009, 05:38:45 PM »
i was told to check it hot and in neutral.
Re: c4 transmission
« Reply #7 on: September 04, 2009, 05:51:10 PM »
That's right.  Level ground, warm engine and transmission,and either in neutral or Park.
