Author Topic: Broken teeth on a starter motor?  (Read 3951 times)
DeusRx
  • Mustang: 1968 coupe
  • Daily driver: same
« on: December 27, 2009, 08:50:44 AM »
Went to start the 351w and nothing.  Examination led to the starter which I saw had about 1/4 of the teeth broken from the shaft.  I have not seen this before and am going to replace it but is it a symptom of something serious or a simple failure?  Is there a tougher starter that could prevent this?
Re: Broken teeth on a starter motor?
« Reply #1 on: December 27, 2009, 06:16:20 PM »
Keep in mind that mechanical things break. That being said, take a look at your flywheel (or flexplate) and starter's teeth. The teeth where they mesh are beveled to make it easier to mesh. If one tooth doesn't mesh, it will jam up. Then it gets "worse". You made the "worse" department. I recomend replacing the flexplate or flywheel and get a new starter. It's usually the flexplate/flywheel that has the problem of lost teeth but a starter is not immune to problems. I've had to replace one flywheel for busted teeth so welcome to the club. Whatever you do, have fun doing it.
holdover
« Reply #2 on: December 27, 2009, 11:27:50 PM »
first, have you been using this starter to start this vehicle, then all of a sudden it won't start and you discovered the broken teeth on the starter drive? If that is the case remove the starter and using a screwdriver turn the flywheel to check for broken flywheel teeth. If all the teeth look good, replace the starter drive (cheap fix) or the starter.
« Reply #3 on: December 28, 2009, 05:58:41 PM »
I have a new starter drive if you want it, just pay for the shipping to you.  I don't need it.
