Author Topic: Brake pads  (Read 1960 times)
ouch1
Brake pads
« on: August 26, 2011, 04:06:23 PM »
Ok so just over 11 years ago I converted the front brakes on my 66 V8 coupe from drums to disks using the SSBC kit p/n A120-20( http://www.cal-mustang.com/STANDARD-FRONT-DRUM-TO-DISC-BRAKE-CONVERSION-KIT-1964-1966-V8-Dual-P13416C860.aspx ). Well since it is not my daily driver and I try to keep the milage down on it I am finally in need to new brake pads for my front brakes. I checked on SSBC's website and they said to use p/n 1600081, and I found them on Summit's website for $72.45 a set. But first off I want to know if anyone happens to know if that is the correct part, and if there is a less expensive part that will work. If you could help me out that would be great.
-Ouch1
BTW here is the link to the part on Summit's page: http://www.summitracing.com/parts/SSB-1600081/
ouch1
Re: Brake pads
« Reply #1 on: November 04, 2011, 04:20:31 PM »
Ok just for everyones info. I ended up calling SSBC and after a little research on thier end they said that I should just ask for brake pads with the part number of D11. I did this and they work great.
