Since you said you had two 390's, I assumed you knew they were 390's, but just need to know the year. There are a few things that will tell you if it is a 390 or not.
Intake manifold runners are partially covered by rocker covers.The exhaust port runners extend out from the head ending with flanges that have the top exhaust manifold bolt holes through these flanges.
5 Valve Cover Bolts.
Distributor goes through the intake manifold, the only Ford engine that has this feature...
You can also research Ford FE engines to get more detailed info.
