Author Topic: Back up light question  (Read 1582 times)
Jeff1967
  • Mustang: 1967 convertible
« on: July 16, 2012, 01:45:25 AM »
For some reason my reverse lights on my 67'quit working,The bulbs seem good? Is there a switch or solenoid that comes in contact with the shift linkage to activate them, if so can someone tell me where is it located?
Thanks in advance
Jeff
Topless_Horse
  • Mustang: 66 convertible
Re: Back up light question
« Reply #1 on: July 20, 2012, 06:36:43 AM »
Which transmission do you have?
If automatic, there's a combination reverse and neutral switch mounted to the side of the transmission where the gear selector shaft goes into the transmission.  If you have a manual, there should be a switch activated by the linkage that comes off the shifter.
You should also check your fuses to make sure they're all good.
Jeff1967
« Reply #2 on: July 20, 2012, 08:05:44 AM »
It is a C4 and was a fuse, all works well now.
Thank you
Jeff
