Author Topic: Any one with experience with a Ford Racing 347 crate engine ?  (Read 5335 times)
exxodus
  • Notre passion? Une légende!
    • Mustang Passion
  • Mustang: 1969 Coupe
  • Daily driver: Exxodus (me)
I'm now ready to upgrade my stock engine to a crate engine from Ford Racing. A 347 stroker, part# M-6007-Z347*
I wonder if soneone here did already get experince with this configuration, or better that already got this engine in his car.
Url: http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=9934
Description.
347 cubic inch
450 hp @ 6000 rpm
400 lb.-ft. @ 4900 rpm
9.7:1 Compression ratio (nominal)
"BOSS" 4-bolt main block
650 CFM Holley carburetor
Forged pistons
Forged steel cap screw connecting rods
Hydraulic roller camshaft, .580" lift intake .602" exhaust, duration at .050" is 232 degrees intake and 240 degrees exhaust with 1.6 rocker arms
Double roller timing chain
Forged steel crankshaft
High-performance rear T-sump oil pan
MSD billet distributor
Ford Racing aluminum "Z" cylinder heads (2.02" intake valves &1.60" exhaust valves)
Roller rocker arms
Single plane Edelb. “Victor Jr.” intake manifold
+New oil and water pumps, +performance oil pan, +high-performance harmonic balancer
+Flywheel +Fuel pump eccentric (Mechanical Pump)
Re: Any one with experience with a Ford Racing 347 crate engine ?
« Reply #1 on: June 04, 2009, 08:47:32 PM »
honestly id go with a stroker from www.fordstrokers.com woody will set you up with a stroker and you can pick your heads etc and it will be far less than 9K$
exxodus
    • Mustang Passion
« Reply #2 on: June 05, 2009, 02:08:22 AM »
I know that there is plenty of engine builder in the US. As i've to order it from belgium, i need something simple to order & ship to europe (via L.A. port, container from a friend).  My friend, isn't in the mustang business, so it's not possible for him, to follow the engine building process for me.
just for info, Gearbox (T5) & Rear End (9'') was build by: Alan from mustang central  (GA).
« Reply #3 on: June 05, 2009, 03:40:48 AM »
im in GA :)
fordstrokers can build you a complete motor, but 9k$ for that ford racing motor is way way way overpriced
give woody a call tell him what that motor has and what you want(how complete) and he can hook you right on up
exxodus
    • Mustang Passion
« Reply #4 on: June 10, 2009, 03:23:43 AM »
Any other advice?
Last post November 12, 2007, 12:42:48 PM
by Thierry
Last post November 25, 2007, 11:40:26 AM
by Thierry
Last post September 30, 2009, 02:18:30 PM
by COBRACRAZY
Last post November 02, 2010, 03:26:22 PM
by 97snakebite
Last post February 21, 2011, 11:16:43 PM
by ol dirty doug
