September 05, 2008, 03:59:06 AM *
Author Topic: Adjust 68 2v 2100 Carb w/ Auto Tran & A/C  (Read 1091 times)
keiken01
Jr. Member
Mustang: 1968 Hardtop
View Profile WWW
Any ideas?
keiken01
Jr. Member
View Profile WWW
keiken01
Jr. Member
View Profile WWW
Attached a pic.
keiken01
Jr. Member
View Profile WWW
keiken01
Jr. Member
View Profile WWW
keiken01
Jr. Member
View Profile WWW
keiken01
Jr. Member
View Profile WWW
keiken01
Jr. Member
View Profile WWW
keiken01
Jr. Member
View Profile WWW
Attached pic.
keiken01
Jr. Member
View Profile WWW
