1974 Mustang II Mach 1
my stang
1966 Mustang convertible
yeller 2
1966 Fastback
Author Topic: Adjust 68 2v 2100 Carb w/ Auto Tran & A/C  (Read 1747 times)
keiken01
  • Mustang: 1968 Hardtop
    • WWW
Any ideas?
keiken01
    • WWW
keiken01
    • WWW
Attached a pic.
keiken01
    • WWW
keiken01
    • WWW
keiken01
    • WWW
keiken01
    • WWW
keiken01
    • WWW
keiken01
    • WWW
Attached pic.
keiken01
    • WWW
Kick-down not working C4 auto
Drivetrain
Peranaman 2 10936 Last post May 19, 2005, 01:01:29 PM
by Ken Moore
Drivetrain
by Thierry
by racedraper
elderbrock carb problems...
asko 0 5571 Last post September 03, 2005, 01:03:58 AM
by asko
"66 289 Carb/Manifold
by Ken Moore
North East USA
Thierry 0 875 Last post November 25, 2007, 06:21:37 PM
by Thierry
Charlotte Auto Fair NC
South USA
by Bossnutt
