  • November 20, 2008, 03:11:08 AM *
  • Welcome, Guest
DSC02946
2007 Ford Mustang GT 520
100 0793
1967 Fastback Mustang Kona
Girl Mustang
Author Topic: Adjust 68 2v 2100 Carb w/ Auto Tran & A/C  (Read 1742 times)
keiken01
  • Mustang: 1968 Hardtop
    • WWW
Any ideas?
keiken01
    • WWW
keiken01
    • WWW
Attached a pic.
keiken01
    • WWW
keiken01
    • WWW
keiken01
    • WWW
keiken01
    • WWW
keiken01
    • WWW
keiken01
    • WWW
Attached pic.
keiken01
    • WWW
Kick-down not working C4 auto
Drivetrain
Peranaman 2 10935 Last post May 19, 2005, 01:01:29 PM
by Ken Moore
Drivetrain
by Thierry
by racedraper
elderbrock carb problems...
by asko
"66 289 Carb/Manifold
by Ken Moore
North East USA
by Thierry
Charlotte Auto Fair NC
South USA
by Bossnutt
