Author Topic: Adjust 68 2v 2100 Carb w/ Auto Tran & A/C  (Read 12375 times)
keiken01
    • My 1968 Mustang
  • Mustang: 1968 Coupe
Any ideas?
I have been rebuilding Motorcraft 2100 carburetors for several years now, and I always set the idle adjustment screws to 2 1/4 turns out initially.   The correct way to adjust them is by using a vacuum gauge, but I just use my ear.
keiken01
    • My 1968 Mustang
Ok, so 2 1/4 turns out to start.  The the book says adjust the screws IN... but I could swear last time I did it, I used the vacuum like you said and adjusted out until I got the max vacuum.
  Yes, you need to have the horns.  Snap a pic of the top of your carb so I can see what damage has been done.
keiken01
    • My 1968 Mustang
Attached a pic.
keiken01
    • My 1968 Mustang
keiken01
    • My 1968 Mustang
keiken01
    • My 1968 Mustang
keiken01
    • My 1968 Mustang
keiken01
    • My 1968 Mustang
keiken01
    • My 1968 Mustang
Attached pic.
keiken01
    • My 1968 Mustang
keiken01
    • My 1968 Mustang
« Reply #18 on: January 03, 2009, 08:30:08 PM »
Hey, just thought I'd let you all know that I did the water 4 gas and it increased my MPG from 11 to 14.  My MPG still sucks, cause I can get 18 MPG from my 2001 4.6L F150, so I'm open to ideas on that problem.  Wondering if a new carb is in order... maybe upgrade to a 4 barrel Edelbrock manifold/carb???   Thoughts??
« Reply #19 on: January 03, 2009, 09:47:17 PM »
Did you turn the idle misture screws all the way in then out 2 1/4 turns then check the vacuum; and adjust for maximum vacuum from there?  Also, spray some carb cleaner around the intake gasket area, and if the RPM's pick up, you indeed have a vacuum gasket leak.  Start a new thread on that water for gas subject and tell us what you know about it.  It sounds very interesting.  If you are going to seriously consider a 4V carb system, be careful about the CFM's you get.  That stock 289 (A code) originally had a 480 CFM Motorcraft carb (4100) so  going too much over that will cause washout, meaning some of the fuel won't get burned and will wash out the cylinder walls.  In other words, a huge waste of gas, and no benefit for performance.  Also consider a dual plane intake manifold as opposed to a single plane.
