Author Topic: 72 headlights go off  (Read 2728 times)
adventurem
« on: May 02, 2009, 08:50:35 AM »
My 1972 headlights sometimes just go off while I'm driving at night: Very bad! When I go to work on them they are fine: fuses, bulbs, etc. all seem good.
I believe thelights are powered by a "fusable link" or resistance wire, but I cannot find any such reference in the wiring diagrams I have. If so: How do I check to see if it's OK?
Anyone have any ideas?
Re: 72 headlights go off
« Reply #1 on: May 02, 2009, 05:30:34 PM »
Welcome to the site.  It could be any number of things, but a worn switch or a loose ground wire will cause the problem.
teven_69_2
  • Faith
  • Mustang: 1966 2 Door Coupe, 289 V8, 4 barrel Carb.
  • Daily driver: Faith
« Reply #2 on: May 24, 2009, 10:13:07 AM »
I just got done taking a road trip and had this same type of problem, I found out that I had a faulty Voltage Regulator, but this would most likely affect your battery as well, not getting the correct charge, etc. Thats just my experience with electrical/lights problem.
« Reply #3 on: May 26, 2009, 07:04:31 PM »
more than likely its the headlight switch, they have an internal breaker and if it gets hot will kick off and the lights go off till it cools
idk if this link will work but autozone list the switch at 12-16$ depending on the build date
http://www.autozone.com/autozone/catalog/parts/partsShelf.jsp?displayName=Headlight+Switch&itemId=prod61266&isSearchByPartNumber=false&sortType=null&totalPages=[I@16493bd&currentPage=1&vehicleNValue=&navValue=15700123&parentId=cat30065&fromString=search&fromWhere=null&filterByKeyWord=headlightswitch&categoryNValue=15799999&categoryDisplayName=Electrical+%26+Lighting&_requestid=986363
« Reply #4 on: June 13, 2009, 05:52:56 PM »
i also have a 72 and i have had similar problems i think that it might be the switch on the dash i will be replacing it soon and hopefully that will fix the problem
jethat
« Reply #5 on: July 13, 2009, 06:55:47 PM »
When I had this probelm in my 71 it was the switch. Got a new one at NAPA..
69fast
  • Mustang: 69 fastback mach 1
« Reply #6 on: July 20, 2009, 10:21:01 PM »
yea put a switch in i
