Author Topic: 67 spindles on a 66 mustang??  (Read 9553 times)
66stang
  • Mustang: 1966 convertible
« on: June 16, 2007, 05:49:51 PM »
i have a 66 mustang with 6 cylinder Suspension and i would like to change it over to 5 lug.  i have a set of 67 spindles but i didn't know if it was possible to put these on it. if so does anybody know what parts i would need to swith these spindles over to my car.
Don A
Re: 67 spindles on a 66 mustang??
« Reply #1 on: February 02, 2008, 03:31:31 PM »
For openers both upper and lower arms--Possibly springs and Most likely linkage--If my memory is correct the holes in the spindles for the linkage are not the same size.
See if you can find a parts book---
« Reply #2 on: February 04, 2008, 12:23:09 AM »
No way. It won't work - at least easily. Keep in mind that a 4 lug to 5 lug conversion also includes the rear axle, which will have to be replaced along with the drive shaft, springs, brakes, and it gets a whole bunch complicated. Don't let this stop you, it's a great project to do and you will learn a lot about your car.
Don A
« Reply #3 on: February 04, 2008, 05:53:10 AM »
66 is correct--total conversion is difficult ---I was speaking of front spindles only which I understood to be the question--I once owned a 67 V8 totally rusted out and a 66 with 6 cylinder--I did transfer the entire system but there were a couple of surprises--One item NOT transfered were the rear springs--I used the 66 springs and booster shocks--
racin66coupe
« Reply #4 on: June 04, 2008, 09:47:06 AM »
if you go to diskbrakeswap.com you can get the granada swap, its complete with spindles, MC, lines etc, ive heard nothing but good about em
« Reply #5 on: June 04, 2008, 03:02:39 PM »
Yes, you can do the Granada swap and wind up with a 5 bolt spindle, but you would be foolish to keep the rest of the 6 banger suspension.  For a few hundred more dollars, you can have a V8 front end.  Then, because you will need either an 8" or 9" rear, you may as well go ahead and get the rear axle and pumpkin with springs as well.  Oh, and if you have the weak assed 3 speed transmission, you may as well go ahead and get a top loader.  Oh, and while you are at it.......... ;D
