Author Topic: 67 Not starting  (Read 954 times)
djg3582
  • Mustang: 65 mustang convertible
67 Not starting
« on: January 09, 2010, 01:57:07 PM »
I have a 67 200CID that has been sitting for 2 years.  When I tried to get it running like it was when it was parked, it would not fire up.  I put gas into the carb and go it started, but it does not seem to run on all cylinders, only partial power.  I changed the sparkplugs and the fuel filter.  Any advice on what it could be?
thanks
Dean
Re: 67 Not starting
« Reply #1 on: January 09, 2010, 06:11:53 PM »
Could be any number of things, but after sitting up I'd check that the points were in good shape and then consider either rebuilding the carb or giving it a very thorough cleaning.  Gas evaporates and leaves varnish that can clog up the jets and idle circuits.  If the gas in the car is 2 years old consider draining the tank and starting with fresh gas.  gas does go a little sour over time.
Re: 67 Not starting
« Reply #2 on: January 09, 2010, 10:38:17 PM »
I totallly agree with Jeff.  Drain the fuel, and put in a few gallons of fresh gas.
Re: 67 Not starting
« Reply #3 on: January 09, 2010, 11:10:34 PM »
Check the compression also to see what cylinders are dead and what not.
Last post December 28, 2009, 12:35:31 AM
by Jaime_302
Last post January 16, 2010, 09:53:33 PM
by BlackShadow
Last post June 10, 2010, 04:33:35 PM
by muncher
Last post September 11, 2010, 10:08:50 PM
Last post September 13, 2011, 06:55:51 AM
by Topless_Horse
