Author Topic: 66 carburetor  (Read 3693 times)
jake66
  • Mustang: 1966 mustang coupe
  • Daily driver: Lexus LS 430
66 carburetor
« on: December 03, 2010, 07:06:50 PM »
Hi, I have a 66 mustang with a 289 and an auto box. The carb fitted is a autolite C7D F -V which idle and  runs rough. My question is should I get this carb rebuilt or source the correct carb for this year and engine.  Thank you.
Joe AZ 2 PA
  • Guest
Re: 66 carburetor
« Reply #1 on: December 03, 2010, 09:14:29 PM »
If you're just doing a stock driver/cruiser go for the correct carb for the motor. . .  8)
Re: 66 carburetor
« Reply #2 on: December 03, 2010, 11:33:30 PM »
Most carburetor rebuild shops sell a replacement model carburetor without any concern about year, features or part number of what you get - in other words, you need a Ford 2100 2 barrel, you get a Ford 2100 2 barrel. The one you have is for a 1967 Mustang, Fairlane or Falcon (Comet too most likely) with an AT and smog. If you have the patients (and luck), the one you want is a C6DF-B (or C6DF-F if you have California smog, DSO 71 or 72). To be truthful, there are internal parts that are different (main jets 51F vs 45F, booster venturi for examples) that make a whole lot of performance differences. Glen (Soaring) rebuilds carburetors to keep busy so when he chimes in, see what he says.
Re: 66 carburetor
« Reply #3 on: December 04, 2010, 03:59:21 AM »
These 2100 carbs are mostlly the same.  It just matters in the hook up..  You can make a 2100 work on any 289 engine.  The best ones are from the 1965-66 Fords though.
jake66
Re: 66 carburetor
« Reply #4 on: December 04, 2010, 06:02:49 AM »
Thank you all for your replies. Can you guys recommend a good shop to buy a replacement carb. I live in Ireland so sending carbs over and back with problems would be costly. Again thank you for your help.
Re: 66 carburetor
« Reply #5 on: December 04, 2010, 08:41:10 AM »
ponycarbs  would be your safe bet, but expensive.  I can rebuild that carb for half that price, but the mailing charge may be expensive on your half.
jake66
Re: 66 carburetor
« Reply #6 on: December 04, 2010, 12:59:38 PM »
Hi Soaring thanks for your reply. I looked at their website and they say their carbs are remanufactured, is that needed or will a simple rebuild work.
Re: 66 carburetor
« Reply #7 on: December 04, 2010, 01:58:23 PM »
A simple rebuild is all you need.  I'm not even sure what remanufactured means.  It could mean they replace the butterfly and all the screws, etc,. but that would be a rare need.  Get the number off the tab and order a rebuild kit from autozone and you could rebuild it yourself.  The kits come with every part you will need.  You can rebuild it yourself and save a whole lot of money.
jake66
Re: 66 carburetor
« Reply #8 on: December 04, 2010, 02:39:55 PM »
Thanks again Soaring, I will look into getting a kit.
jake66
Re: 66 carburetor
« Reply #9 on: December 05, 2010, 07:36:10 AM »
Some info I found say the carb I have may be for a 351 5.8 1970 mustang, any thoughts on this. Thanks
Re: 66 carburetor
« Reply #10 on: December 05, 2010, 12:08:46 PM »
Pay attention grasshopper -
"The one you have is for a 1967 Mustang, Fairlane or Falcon (Comet too most likely) with an AT and smog."
jake66
Re: 66 carburetor
« Reply #11 on: December 05, 2010, 12:31:26 PM »
So sorry Master I bow to your superior knowledge. Other Master must be wrong   ;)
Re: 66 carburetor
« Reply #12 on: December 05, 2010, 09:56:34 PM »
Bow not necessary, enlightenment is. Other "master" have flaw, need enlightenment (and a Ford Car parts Book).
jake66
Re: 66 carburetor
« Reply #13 on: December 07, 2010, 06:28:50 AM »
Thanks 66GTKFB Other master has been enlighten.  ;) I will order a kit in the new year and see if I can get it to run smooth.
Re: 66 carburetor
« Reply #14 on: December 07, 2010, 03:51:39 PM »
We'll get her running
jake66
Re: 66 carburetor
« Reply #15 on: December 08, 2010, 12:44:05 PM »
Thanks Soaring, I am missing the choke shield and the dashpot so in the new year I will get working on it.
Re: 66 carburetor
« Reply #16 on: December 08, 2010, 06:12:13 PM »
OK.  Let me or Jim know if you need further help.  You can buy whole carbs off Ebay with all the parts you are missing.
jake66
Re: 66 carburetor
« Reply #17 on: December 11, 2010, 03:25:46 PM »
Thanks Soaring I will have a look.
