Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Contact
Login
Register
Forum
Technical forums
Topic:
65 starter problem
Pages:
1
Go Down
Author
Topic: 65 starter problem (Read 1404 times)
blair/paul
Gender:
Mustang: 06 base coupe
Daily driver: 06 base coupe
65 starter problem
on:
July 22, 2012, 11:38:02 AM »
we have a 65 k code that old starter was grinding the ring gear on flywheel. replaced starter, ring gear, and spacer between bell housing and block. starter is grinding into ring gear again! help!!
70_Cougar
Jr. Member
Gender:
Mustang: Early 1965
Daily driver: MR2
Re: 65 starter problem
Reply #1 on:
July 22, 2012, 05:32:38 PM »
Hi blair/Paul, Welcome!
This is a very common problem and it is often perpetuated by the catalogs being wrong at the parts supply houses. I guess that the new starter looked just like the starter that has been grinding for a while? That starter that has been grinding for a while....was it the original?
Well if you read the writeup in the attached line, you will become the next Ford starter expert.
http://www.bcbroncos.com/ford%20starters.pdf
Good luck and I hope it leads you down the correct road on your starter problems.
John
blair/paul
Gender:
Reply #2 on:
July 22, 2012, 06:52:40 PM »
Thanks John. You gave us a lot of info here. I'll get into it in a few days and let you know what we find. Blair
Pages:
1
Go Up
Forum
Technical forums
Topic:
65 starter problem
Navigation
Used Cars for sale
Ford Mustang classifieds
Powered by
EzPortal
