Author Topic: 65 starter problem  (Read 2391 times)
blair/paul
  • Mustang: 06 base coupe
  • Daily driver: 06 base coupe
65 starter problem
« on: July 22, 2012, 11:38:02 AM »
we have a 65 k code that old starter was grinding the ring gear on flywheel. replaced starter, ring gear, and spacer between bell housing and block. starter is grinding into ring gear again! help!!
70_Cougar
  • Mustang: Early 1965
  • Daily driver: MR2
Re: 65 starter problem
« Reply #1 on: July 22, 2012, 05:32:38 PM »
Hi blair/Paul,  Welcome!
This is a very common problem and it is often perpetuated by the catalogs being wrong at the parts supply houses.  I guess that the new starter looked just like the starter that has been grinding for a while?   That starter that has been grinding for a while....was it the original?
Well if you read the writeup in the attached line, you will become the next Ford starter expert.
http://www.bcbroncos.com/ford%20starters.pdf
Good luck and I hope it leads you down the correct road on your starter problems.
John
blair/paul
« Reply #2 on: July 22, 2012, 06:52:40 PM »
Thanks John. You gave us a lot of info here. I'll get into it in a few days and let you know what we find.  Blair
