girl mustang med
Mustang girl
1993 Cobra Mustang
girl mustang white
1969 Mach one
Author Topic: 65 A code not starting when cold?  (Read 5867 times)
mike
« on: June 30, 2006, 09:07:21 AM »
I have a 65 A code convertible with 5700 miles since the engine was rebuilt. When the car was cold and had been sitting in the garage for a day or two, I would press the gas pedal once all the way and release, and the car would start pretty mutch right away. Once the car was warm, there was no need to press the gas pedal. Lately, I press the gas pedal once when cold just as i've always have, and it takes me about 3 times of turning the ignition before the car starts. When warm it still starts on the first try.
Any idea of what the problem might be? Also, should I use premium or regular gas?
Thank you for your help, Mike from Miami
Jerry Baker
    • WWW
Re: 65 A code not starting when cold?
« Reply #1 on: June 30, 2006, 12:44:08 PM »
I can't help with the first part of your question because Im in the same boat.
As for the gas question I can.  First of does the car knock or ping?
if the answer is no then you don't have to run the high octane gas.
I work in a lad for a local oil refinery and I asked our lab manager the same question and he said if its not then no.  If it pings then yes.  Thats all octane is.  A anti knock additive.
Jerry D. Baker (AKA The GodFather)
Founder and President of
The Mustang Mafia of America Car Club
http://www.themustangmafia.com
Join the Family if you Dare!
http://www.mustangv8.com/en2/modules/myalbum/viewcat.php?uid=118
Rate my Rides.
racedraper
« Reply #2 on: June 30, 2006, 02:44:07 PM »
is in manuel or electric choke. It might need adjusted or you could be running a little rich. if you run rich it will put too much gas on the plug when you shut the car off unitl it gets hot enough . take the plugs out to  check the color.
when I raced quads I would check my plugs by running it in third gear and shut it down at 3rd gear and coast to a stop to see how the plug looks while under a load . some people would check at idle but its not accurate. thats why dyno tuning is the best way to go.
mike
« Reply #3 on: July 12, 2006, 07:00:12 PM »
I fixed the problem! My carb is a 4 barr. Autolite. I replaced the carb. diafram that links the gas pedal assembly to the carb. I had a small gas leak from that area on the carb from not running the car as mutch as i should have. The old diafram had dried-out, thence not shotting and opening in order to activate fuel flow.
Thank you all for your help
my c code coupe to shelby performance upgrade.
Your Mustangs
13lazer 1 5037 Last post April 02, 2006, 11:38:27 PM
by Jerry Baker
1996 MUSTANG: failed emissions... P0174 OBD-II Trouble Code...System Too Lean (Bank 2)
4.6 Mustang technical forum
bandit1 1 3918 Last post January 23, 2008, 08:26:38 PM
by rich96cobra
cold start engine knock?
Camster 2 3823 Last post November 02, 2008, 05:34:33 PM
Starting a post
Europe
rouge67 7 5196 Last post December 03, 2006, 09:13:52 AM
by rouge67
351 Cleavland Not starting.
jemoore24 2 980 Last post February 25, 2008, 03:42:42 AM
by rmodel65
Another C code coupe for sale
Soaring 1 1100 Last post April 07, 2008, 08:01:31 PM
by Thierry
73 Mustang Not Starting HELP!!!!!!!!!!!!!!!!!!
Mustang Discussions
jemoore24 4 886 Last post June 01, 2008, 12:26:34 AM
by Mark57
2002 gt cold air intake!
Parts wanted
2002 GT 0 392 Last post July 05, 2008, 08:26:36 PM
by 2002 GT
Dealer said cold-air intake worse fuel mileage...
Konrad 14 1976 Last post September 29, 2008, 01:00:03 AM
by primus1121
1966 'A' code GT Fastback!! $13,000
66gtfb 0 135 Last post October 27, 2008, 01:05:15 PM
by 66gtfb
