hI,all got a 460 going to build for my 72 mach 1 .Any suggestions of what i should do for motor.Was thinking of get boss heads and better cam.
Quote from: mustanger on October 07, 2006, 10:04:02 PMhI,all got a 460 going to build for my 72 mach 1 .Any suggestions of what i should do for motor.Was thinking of get boss heads and better cam.Boss heads will not work, thats a whole different animal. They had to contract modify the front end of the Boss mustangs to get the motor in to sell them to the public. Plus they only sold a very limited amout of the Boss headed motors, a needle in the haystack. aluminum heads are not nessacary in you have a decent set to start with, but are great if you have the money. What is the part casting # for the heads you have? I run interceptor heads on my 460 with neck snapping results. What is your end goal for this motor, street, strip, both?Here is a link to give you an idea of what you can work with.http://www.reincarnation-automotive.com/casting-numbers-descriptions-1-index.html
