Mustang girl
Mustang girls
1967 N.O.S. 428 COBRA JET
1965 Mustang fastback
89 motor w/ chrome
Author Topic: 429 over heating  (Read 1317 times)
h70mach1
  • Mustang: 1970 mach1
429 over heating
                      thanks for reading
                                             Andy
Re: 429 over heating
h70mach1
h70mach1
h70mach1
h70mach1
CrunchySkippy
  • Mustang: 1967 Coupe
-bill
h70mach1
h70mach1
Q8_HATCH
  • Mustang: 92 hatch
In progress: 410W N/A, Canfield cnc heads, Camshaft innovation HR cam, TFS-R EFI intake and much more!!
87 over heating
5.0 Mustang technical forum
by bradley
66 mustang 289 over heating
Jackie Jameson 10 3786 Last post June 23, 2008, 04:33:41 PM
by Lissesred66
Over Heating
Mustang Discussions
by petty
