Author Topic: 429 over heating  (Read 10570 times)
h70mach1
  • Mustang: 1970 mach1
429 over heating
                      thanks for reading
                                             Andy
Re: 429 over heating
h70mach1
h70mach1
h70mach1
h70mach1
CrunchySkippy
  • Mustang: 1967 Coupe
-bill
h70mach1
h70mach1
Q8_HATCH
  • Mustang: 92 hatch
Lovebee06
« Reply #15 on: August 01, 2009, 12:36:36 AM »
Overheating of an economy occurs when its productive capacity is unable to keep pace with growing aggregate demand.
________________
Basement dehumidifier
ibox
  • Mustang: 1970 Mach 1
« Reply #16 on: August 30, 2012, 11:34:24 AM »
Hi
I know this is an old thread, bu since I found it very usefull, and maybe I can get some more info from it. I wantd to keep it alive :) Also i live in norway so english is not my first language, so have that inmind when trying to understand my "nors english" :)
I have the exact same problem, a 1970 mach 1 with a 429 (460 really). No space for a puller. However I'm now thinking of trying to move the radiator forward, but it will seriously alter the front of the engine compartment. I have only one pusher.
At idling it's ok, but soon as you step on the pedle it overheats and it's hard to get it cool again. But in general when you drive the car down the road, fans are not ment to cool the engine. I guess the pusher will block the air.
anyway, i was intrested in how you put 2 fans in there, I cant see that there is space for it. Atleast if you want the fans to be snugly fitt towards the radiator. any pictures?
I've also heard that to much timing advance could be a problem, but how much should it be, I have played with it from 5-20 degrees. I have it set at 10 now. It should be mentioned that I have a MSD ignition, maybe the curve is to high or something.
I'll go and try and "burp" the engine now... i've always had a feeling i wasnt able to bleed it good enough. (there should have been a bleed screw :))
ibox
« Reply #17 on: September 01, 2012, 02:55:53 PM »
Just wanted to let you know of my progress.
I burped the engine, I'm not sure this worked or not. But maybe. In my mustang the 429 sits a bit high (because it has to). Soo it's very possible that this is a good trick.
I advansed the timing to about 8 degrees, i had it lower. Then i got a better idle and could turn down the idle adjustment of the carb. Maybe i'll go even higher later.
Finaly I took a leep of fate like mentioned in this thread and removed the pusher fan, running with no fan.
I tok a 30 min drive and no overheating, running aroud 200-220 i estimate. This was what the termocap on the radiator showed. The diale in the car was pointing straight down, so i'm a very happy camper now. :) I can start thinking about fine tuning with different temorstats now :)
Next step would be to move the radiator half inch or as much as I can to fit a fixed machanical fan in there. A flex balde maybe. I have half inch room from the waterpump to the radiator. But I belive I can modify the radiator suport enough to get the room.
For refferance to other readers, here is my setup.
1970 Mach 1
.030 bored 460
Edelbrok preformer RPM setup (cam, intake, carb)
MSD inition
Thank you very much for this thread.
