Author Topic: 429 heads  (Read 3577 times)
h70mach1
  • Mustang: 1970 mach1
429 heads
« on: January 07, 2009, 06:13:40 PM »
Hi I asked a question on here before and got great answers and ideas so i thought i would try again.
I have a 1970 429 with the dove heads. I do not have adjustable rocker arms but i do have studs, screwed into the head that you torque the rockers on.
The question I have is can i change the studs out and install the adjustable studs.   I would like to install a larger cam and was told without adjustable rocker arms I cannot run larger than a .500 lift.
  Any info would be appreciated  thank  Andy
Re: 429 heads
« Reply #1 on: January 07, 2009, 07:04:03 PM »
My suggestion is that you do some research such as reading "How to rebuild your Ford V8 351C-351N-400-429-460" written by Tom Moore.  http://books.google.com/books?id=MDw7l7wHs4oC&pg=PA33&lpg=PA33&dq=429+adjustable+rocker+arms&source=bl&ots=hUmHRiQdH2&sig=ze-lVUdBi34qA5GyfKnKmDq-XUQ&hl=en&sa=X&oi=book_result&resnum=1&ct=result
h70mach1
Re: 429 heads
« Reply #2 on: January 07, 2009, 08:07:28 PM »
thanks  I actually just got done getting info out of that book. i do have it and was reading it after i posted the question.  i found out the adjustable rocker arm studs are for solid lifter engines and non adjustable are for hyd. lifters.        so now i was wondering if anyone knows the max lift i can have in a cam for the stock heads with stock valve train?
      thanks
Re: 429 heads
« Reply #3 on: January 07, 2009, 08:15:12 PM »
      thanks
That is an extremely technical question, and one that I don't think you will get an answer on here.  You might want to consult with a Ford tech in your local area to get that answer.
h70mach1
Re: 429 heads
« Reply #4 on: January 08, 2009, 04:54:11 PM »
thanks  i appreciate you not guessing like some people would, i will do that
gomer
  • Guest
Re: 429 heads
« Reply #5 on: January 14, 2009, 06:50:12 PM »
Hi, First you will have to mill off the pedstal. Then drill and tap holes for studs. Any good machine shop can do it.
Last post October 11, 2009, 03:08:41 AM
by Cobra GT
Last post November 14, 2009, 07:45:59 PM
Last post November 11, 2009, 07:11:02 PM
by Areese3990
Last post February 02, 2010, 10:57:39 PM
by nm12racer
Last post March 12, 2011, 04:44:57 PM
by jethat
