Author Topic: 351c build coming to a close  (Read 2094 times)
« on: January 24, 2010, 07:42:14 PM »
So after nearly two months of constant screw ups from my machine shop my Cleveland is finally coming to an end. Here are the specs:
351c CJ bored .30 over (357 CID)
Standard crank ground and polished
Completely balanced
Forged Domed pistons (10:1 compression)
ARP head/rod bolts
4v heads with new stainless steel valves, ported and polished
ford racing roller rockers
comp cams roller cam .612 lift/304 duration/110 degree lobe separation
Standard rods re-sized with ARP bolts
Hooker headers
Weiend X-ellerator aluminum intake
Holley 770 cfm street avenger carb
MSD everything
im sure there is more but i cant think of it off the top of my head
Target horsepower 450+
Backed by a toploader 4 speed close ratio w/ Hurst shifter.
If i think of more ill post it, thanks for reading.
Re: 351c build coming to a close
« Reply #1 on: March 02, 2010, 12:33:06 AM »
here are some pics finally of the build. Before, during, and after. The motor is not 100% yet but its almost there.
« Reply #2 on: March 02, 2010, 12:33:50 AM »
More
« Reply #3 on: March 02, 2010, 12:34:26 AM »
Still more
« Reply #4 on: March 02, 2010, 12:34:54 AM »
Last one til its in the car about 3-4 weeks from now.
BlackShadow
  • Mustang: 1965 Mustang 2+2
« Reply #5 on: March 02, 2010, 01:30:13 AM »
That is one Sweet Motor..  ;D
« Reply #6 on: March 02, 2010, 01:36:17 AM »
thank you very much. ;D
« Reply #7 on: March 02, 2010, 02:29:58 AM »
Looks good Tim.  Keep us posted.
« Reply #8 on: April 19, 2010, 02:46:24 PM »
We need an update!!!!
« Reply #9 on: April 21, 2010, 02:21:09 PM »
Well the new cowl is being welded in today so once that is finished im spraying the engine bay and the motor should be able to go in the car by the end of this week or beginning of next. We'll see!
« Reply #10 on: April 21, 2010, 05:59:12 PM »
Take your time and get that engine bay really clean and everything tucked away.  I would use a wire wheel and get that sucker all the way down to raw metal, then sand blast or medium blast  it before paint.  That is something you will only do in your lifetime.
« Reply #11 on: April 21, 2010, 06:33:12 PM »
Yup i've been wire wheeling the hell out of it. I scraped off all the old silicon that was causing some surface rust and seam sealed it all, next is some clean up then paint.
« Reply #12 on: April 21, 2010, 06:42:29 PM »
I would lay down a good coat of POR 15, another rust inhibitor or at least a coating of Primer before I added the color. I would use a black semi-gloss paint too.
« Reply #13 on: May 04, 2010, 07:26:40 PM »
Sorry for the delay Tim-hope these help
« Reply #14 on: May 04, 2010, 11:30:30 PM »
Thanks for the pics, and no problem i haven't been able to work on that part of it anyway.
« Reply #15 on: May 05, 2010, 12:47:25 PM »
How about pics of that engine bay before the motor goes in?
Meric
  • Mustang: 1972
« Reply #16 on: May 18, 2010, 01:28:29 PM »
beautiful job tim let me know how it works in the end, have a 351c myself just unsure what final out come will be
« Reply #17 on: May 22, 2010, 01:26:24 AM »
Thanks a lot, and will do. Let me know what ya decide to do with it ;D
Last post August 30, 2009, 05:32:46 PM
by f1rstGt
Last post July 04, 2009, 09:17:50 AM
by Jeff1967
Last post November 12, 2009, 03:19:00 PM
by Blown2v
Last post February 02, 2012, 07:05:30 PM
by Amy75
Last post March 25, 2011, 03:31:44 PM
by mystichris@MD
