Author Topic: 351 heads on 302 plus 4100 autolite any suggestions  (Read 2593 times)
torres78
  • Mustang: 68 Coupe
« on: December 30, 2009, 02:52:44 PM »
I am thinking of putting a new set of heads on my 68 302 and I am considering a set of 351w DOOE with a 4100 autolite and the proper intake, I am keeping the stock cam for now. I am wondering if anybody has something similar to this , who can tell me they opinion, or someone with enough knowledge, I am also adding a set of 355 gears.
Re: 351 heads on 302 plus 4100 autolite any suggestions
« Reply #1 on: December 30, 2009, 04:09:37 PM »
Interesting concept, but there are several questions you need to address:
- A set of "D0OE" heads (there are two variations, a "-C" and a "-G") have a chamber volumn of 60.4cc, stock 68 302 heads are 63cc so you increase the compression ratio, and the intake and exhaust valves are larger. So far a positive, I believe the problem is the stock intake manifold not mating, a possible difference in gaskets and head bolts.
- Which 4100 carburetor are you considering, the 480cfm or the 600cfm? The difference is best defined as venturi diameter, 1.08 vs. 1.12. The Autolite 4100 is an excellent carburetor: simple, efficient, economic, reliable.
- You got all that good air/gas mixture on the top, but getting it into the cylinders and there you fall flat. You don't "breathe". A cam is a big deal and would be best thing to do at the time the heads went on.
- Now, how do you get all that "exploded" air/gas mixture out? No headers in the plan?
- A set of 3.55:1 gears are fine. What transmission modifications?
My recomendations:
- Rework the 302 heads (install bigger valves, shave 0.030 of the mating surface, polish ports). You will probably need to rebuild the 351W heads anyway.
- Put in a cam.
- Add headers and a dual exhaust system.
- Install a high rise manifold and an Autolite 4100 1.12 type carburetor.
- Convert the distributor to a Pertronix II type.
- Gear selection is ok, but do them last.
torres78
  • Mustang: 68 Coupe
« Reply #2 on: December 30, 2009, 04:42:50 PM »
Thanks Jim, I do have headers an dual exhaust, I was thinking on the Autolite 4100 1.08 ventri 480CFm I have heard that the  600 might be a little to big for the 302. So it's better to rework those 302 heads than invest the time and money on the 351w.
The cam really is a good add on but the biggest thing about the cam is to get the right one and thats where I come short on the cam selection.
nm12racer
« Reply #3 on: February 02, 2010, 10:57:39 PM »
Hi
You could also look at the Gt40 heads.
They are 302 heads, Modern valve train.
You might need to get different push rods.
 ;D
Last post December 08, 2008, 09:01:51 PM
Last post February 05, 2009, 12:12:08 AM
Last post November 06, 2009, 06:57:25 AM
by trbleman
Last post June 15, 2010, 04:20:08 PM
Last post June 21, 2010, 04:14:17 AM
