Author Topic: 351 Cleavland Not starting.  (Read 2857 times)
jemoore24
« on: February 24, 2008, 07:57:44 PM »
 Just purchased 1973 Mustang Coupe. Has 351 Cleavland. I was told that car has not run for a year. I put new battery and stater selinoid on today. Car turns over but wont fire up. Do I have to do something special to get a engine fired up that has been sitting a while? Thanks for the imput. jemoore24
Re: 351 Cleavland Not starting.
« Reply #1 on: February 24, 2008, 09:47:31 PM »
Most likely you aren't getting any fuel in the carburetor, so don't have the fuel issue solved yet.  Take the fuel line off the carburetor, and put a glass jar under the line and have someone turn over the engine.  If you are getting fuel at the line that feeds the carb, then hook it back up and pump the accelerator until the engine fires while you are cranking it.  If there is no fuel coming out of the line, then your fuel pump has gone south.  Replace it, and try again.  If that doesn't work, then get back.  You may have some issues further down the line.
« Reply #2 on: February 25, 2008, 03:42:42 AM »
yeah and check the points also you getting any spark?
Last post November 30, 2008, 09:32:03 PM
Last post June 22, 2009, 10:25:56 PM
by Jaime_302
Last post September 17, 2009, 11:37:00 PM
by Jaime_302
Last post October 28, 2009, 09:06:47 PM
by Jeff73Mach1
Last post December 15, 2009, 01:40:02 AM
by Konrad
