Author Topic: 302  (Read 7350 times)
Guest
  • Guest
302
« on: December 21, 2005, 09:24:22 PM »
I needed to know how to get the pistons out of my stuck 302. I cannot reach the connecting rod nut on a few pistons because of their position.  How would i get the pistons out without damaging them also. everything else is stripped of but crank pistons and rods. any help would be great im a first time rebuilder of engines.
Guest
  • Guest
Re: 302
« Reply #1 on: January 05, 2006, 04:49:48 AM »
Have you tried turning the crankshaft?
Guest
  • Guest
Re: 302
« Reply #2 on: January 07, 2006, 03:10:22 PM »
The pistons are stuck in the cylinders and i cant turn the crank.
Guest
  • Guest
Re: 302
« Reply #3 on: January 10, 2006, 06:02:23 PM »
i had the same problem because 2 pistons broke, what I did was to turn the crankshaft witha breaker bar using the bolt from the pulley, and to get them out I used a bar and I hammered them out, just be careful not to damage anything, it took me awhile but it worked
