If you want to use 351 heads you need to lok for these casting numbers C90E-B, C90E-D, D0OE-C, D0OE-G, D0OZ-C these heads have the smaller cc chambers and will not drop compression and flow pretty good for stock heads. Since they are from a 70 mustang they are probably the ones you need, but check numbers to be sure
