Author Topic: 302 and 351W heads  (Read 2690 times)
timsweet
  • Mustang: 1970 Coupe
  • Daily driver: 2007 Corvette
302 and 351W heads
« on: December 04, 2010, 08:55:01 AM »
will 351W heads from a 70 Mustang go on a 302 block?
Re: 302 and 351W heads
« Reply #1 on: December 04, 2010, 02:12:41 PM »
Basically the same animal.  351W heads have larger valves and a bigger combustion chamber..and they will flow much better..but you sacrifice compression as the bigger chambers will drop compression..a 302 intake as well as exhaust manifolds will bolt right up..the 351 heads are exactly the same size except for the valves and chambers.
« Reply #2 on: December 05, 2010, 12:14:05 AM »
Been a while since I messed with windsors, but IIRC the 351 heads use larger head bolts and you have to use a specific headbolt that is stepped for the swap.  Otherwise they are interchangeable.
thundertc64
  • Mustang: 73 Mach 1 H code
« Reply #3 on: December 12, 2010, 11:40:50 AM »
If you want to use 351 heads you need to lok for these casting numbers C90E-B, C90E-D, D0OE-C, D0OE-G, D0OZ-C    these heads have the smaller cc chambers and will not drop compression and flow pretty good for stock heads. Since they are from a 70 mustang they are probably the ones you need, but check numbers to be sure
