Author Topic: 289 wont start  (Read 2714 times)
srvblues
  • Mustang: 1967
  • Daily driver: just weekends
289 wont start
« on: October 06, 2009, 02:33:15 PM »
Okay, can someone explain to me on proper tune up steps from finding tdc to the finish!   please keep it simple Thanks Jeff
holdover
Re: 289 wont start
« Reply #1 on: October 16, 2009, 10:15:16 PM »
Two ways, here is # 1 DO both ways with coil wire unplugged or removed
Take out # 1 spark Plug
Use a remote starter button or have someone “click” the ignition key to start position
Have finger over spark plug hole, when you get a pop that was cyl at TDC or very close.
Look at timing mark on  damper and confirm pointer is at TDC. May have to turn crank a slight bit to get to TDC
Pull dist cap, rotor should be pointing to #1 wire, be sure to check firing order and rotation order
Second way
If right valve cover is off, or whichever valve cover is on the #1 side, click over starter, watch valves, when both intake and exhaust on # 1 don’t move you are on the  compression stroke, again confirm mark on damper, may have to turn crank a bit to get to TDC
follow above with dist cap etc.
Re: 289 wont start
« Reply #2 on: October 17, 2009, 12:55:10 PM »
Another interesting way to get the #1 piston to the top of the cylinder, is to stuff a rag in the plug hole, and when the compression pops out the rag you are at TDC.  The rag will make a very audible pop sound when it blows out.   ;D
srvblues
  • Mustang: 1967
Re: 289 wont start
« Reply #3 on: October 21, 2009, 07:30:28 PM »
I got her going  thanks for everyone for the help
