Hey guys. I got recommended to this forum by aussie66fastback(i think thats right) From MF.com. Ok to the point.First, I have a 71 sportsroof, and I want to take it with me, when i move(going to college). It had factory a 351c 4v in it, but it is out due to cam bearings going out, it's .03 over already, and i don't want to rebuild it until the car has been restored, because i am going to put the factory engine in for value reasons.Until then, I want to put an engine in it, that can handle a 1300mile trip one way, for a move. Yes, bad choice for gas mileage but i want to take her with me, to work on during college.So, I want to put a 289 in it(i loathe the 302, just because it is so common, and I know, I know. The 302 is just a stroked 289). First v8 I had was a 289 hipo. Fell in love with it.I want the 289 because it will fair a bit better on mileage, than a 351w, or 302 would(arguably). I'm running 3.02 gears, and 4th gear is 1.00 ratio(wide ratio toploader). So, i will be turning aprox 2800 rpms to do 75mph.Now, I was curious what is the difference between the 289's? I was referencing some info, such as http://www.carmemories.com/cgi-bin/viewexperience.cgi?experience_id=131 and it looks to be by the specs of the valves, that all the heads are the same? Is that true, or are the 2bbl layouts using smaller ports?The only difference in hipo heads, and just 4v heads are the thread in studs, and the 'cups' to the seat of the valve spring yes?Also, just for sake of asking, are the 302 maincaps interchangable with the 289 ones? I was looking for aftermarket maincaps, and such and had run across a few 289/302 maincap advertisements, but was unsure. I would imagine they would, as the difference is the cranks offset, and the diameter should be the same? (just guessing due to 289/302 rebuild kits using same main bearing/rod bearing sizes). Thanks for looking, and hopefully some more specific info that I was needing. Thanks guys. You can be sure I've missed something i wanted to know, and will be posting more newb questions :-pIf you are a typical college kid, you don't have much money. Get a 302 and get off your 'high horse'. Unless you have a rebuilt 289 waiting to be installed, don't limit yourself, and consider a rebuilt 351C to use as well. As well a engine size, gearing and carburation, mileage is also a function of the foot feed (you can quote me on that). As to the rest of your questions: - there are two basic differences in 289 castings, 5 bolt and 6 bolt - the way they bolt to the transmissions. You want the 6 bolt type.- Heads. There are over a dozen different heads, mostly valve and combustion chamber differences. Ford used the same heads on 2 barrel and 4 barrel engines with pistons making up the difference in compression ratios. HP heads are unique in their use of special rockers, studs and springs. Machining makes them work. You will pay big bucks for them, if you can find them.- Main caps: what ever you select, stock, donor or performance, they will need machining, so don't worry about them. What is a 3.02 rear axle ratio?Remember this: 'Speed (and performance) costs money - how fast can you afford to go?'.Jim
