Author Topic: 289 Small Block  (Read 4098 times)
289225hp
289 Small Block
« on: October 15, 2010, 08:20:34 AM »
Hello , I need to remake my 289 well you know the " Comp Cams " kit includes
Camshafts , lifters , matched valve springs , retainers , locks , seals , timing chain set ,
assembly lube , decals  ;D::)
Fred
Re: 289 Small Block
« Reply #1 on: October 15, 2010, 08:33:57 AM »
OK Fred.  Sounds like a good plan.
289225hp
Re: 289 Small Block
« Reply #2 on: October 15, 2010, 09:48:58 AM »
Comp cams , Great mileage , smooth idle - rpm 600/4800
 or, low and mid range , good idle - rpm 1000/5200 .
4 in 1 exhaust manifolds with Cherry Bomb turbo come with me , is it good  ::)
289225hp
Re: 289 Small Block
« Reply #3 on: October 20, 2010, 11:12:57 AM »
Ok for low and mid range, good idle - rpm 1000/ 5200
What is the max bore for 289 / 302 ci .
Re: 289 Small Block
« Reply #4 on: October 20, 2010, 12:57:22 PM »
The machine shop that did my original untouched 66 289CID engine recomended 0.020in overbore as a start. The procedure he used was to bore 0.018in first, and then hone the rest to 0.020in. The bad news was it didn't work, there was a small hole in no. 8 cylinder. I got another untouched date coded block, did the same overbore and this time it was OK. As I didn't want to have the first block sleeved, so I sold it to someone who didn't mind the sleeve. You take your chances. Standard overbores for 289CID engines are: 0.020in, 0.030in, 0.040in and 0.060in (Note: 0.050in over pistons are hard to find). As to max, a 0.060in overbore will get you about 297CID. The 302CID engine was a stroked 4.00in bore. Conventional wisdom states that any small block Ford engine (289, 302 and 351W) run hot when overbored so figure on a larger radiator. Crate motors get 347CID from a start of 302 but they are new castings, subjected to high manufacturing standard and are assembled individually, not mass produced. A 351W can be bored and stroked to 427CID. I know a guy with a repro 65 Cobra with a 351W/427Cid engine and it is awesome.
289225hp
Re: 289 Small Block
« Reply #5 on: October 20, 2010, 01:46:23 PM »
Thanks for news Jim , i do not find above 4.030 bore rings and piston .
Re: 289 Small Block
« Reply #6 on: October 20, 2010, 02:31:08 PM »
3.0 and 4.0 are the standard bores.  Anything more will cause a ton of overheating problems.  How's the weather in France?
289225hp
Re: 289 Small Block
« Reply #7 on: October 20, 2010, 02:33:31 PM »
J'ai vieille 302 pour les pièces ci-je envoyer avec l'atelier d'usinage
Re: 289 Small Block
« Reply #8 on: October 20, 2010, 06:18:48 PM »
Uh, does that mean you are cooking with wine (chicken with Gewurztraminer tonight for me) or the light is out in the bathroom?
289225hp
Re: 289 Small Block
« Reply #9 on: October 21, 2010, 12:17:33 AM »
 :-[ Sorry , i have engine 302 ci for parts . my block 289 is 4.032 bore  :(
( no chiken with wine  ;D ) told how Magret de canard sauce champignons
                                                        ( Duck breast with mushroom dressing )
289225hp
Re: 289 Small Block
« Reply #10 on: October 21, 2010, 12:43:41 AM »
the weather is verry sun verry nice temperature
289225hp
Re: 289 Small Block
« Reply #11 on: October 21, 2010, 01:20:09 AM »
I leave school to learn English al dream that the lady is verry nice  ;)
sujon420
Re: 289 Small Block
« Reply #12 on: November 05, 2010, 06:53:14 PM »
