Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Contact
Login
Register
Forum
Technical forums
Topic:
1968 Mustang exhaust leak
Pages:
1
Go Down
Author
Topic: 1968 Mustang exhaust leak (Read 14029 times)
wcm3232
on:
June 15, 2006, 02:43:37 PM »
I have a 68 Mustang Convertible. Every time we go for a drive in it we smell like exhaust fumes. I have had the donuts replaced and can find no exhaust leaks. Does anyone have any ideas as to what the problem is. My wife will not ride in the car and that is a problem.
racedraper
Sr. Member
Re: 1968 Mustang exhaust leak
Reply #1 on:
June 15, 2006, 04:23:00 PM »
well after all you are in a convertable.lol how is you exhuast routed? out the side or back. I thought the smell what is driving a classic is all about.
Guest
Reply #2 on:
June 18, 2006, 09:12:23 PM »
wcm3232
Reply #3 on:
June 19, 2006, 08:07:42 AM »
No black smoke and the car runs great. A little sluggish in the morning but good. What would I need to do to the carb to fix the problem if that were it?
wcm3232
Reply #4 on:
June 19, 2006, 08:13:01 AM »
The exhaust is routed out the back. Dual exhaust and sounds good. I tried classic car smell line on my wife several months ago and it fell on deaf ears. I have wondered before if there were some kind of back draft or something causing the exhaust to enter the cab. A crazy idea but that is where I am with this. There are a couple of openings in the firewall. Even without an exhaust leak, could this be the problem?
Thanks for the help.
Guest
Reply #5 on:
June 19, 2006, 07:40:58 PM »
I'am just thinking outside the box here. How about the crankcase vent ,, you said the firewall has holes in it . It could be from that insted of exhaust . Can both smell the same.
wcm3232
Reply #6 on:
June 19, 2006, 08:13:31 PM »
I will take a look at that when I get the time. Thanks for the suggestion. I am going to seem ignorant but where would the crankcase vent be located? I am not a mechanic.
Guest
Reply #7 on:
June 20, 2006, 07:04:04 PM »
It's a host from valve cover to bottom of carb. Make sure P V C valve is working, pull it out and shake it . should have a rattle sound . If not replace it .
Guest
Reply #8 on:
June 20, 2006, 08:41:46 PM »
Guest
Reply #9 on:
June 22, 2006, 05:20:27 PM »
How true but must cars get fresh air from just in front of windshield. As air ffows over hood it hits windshield. This makes a high pressure area at base of it . It's forced into louvers between windshield and back of hood. And most hoods don't seal 100%. Air from engine area can be pulled into car.
Ken Moore
Jr. Member
Reply #10 on:
December 13, 2006, 06:21:53 PM »
my 66 hardtop does this also ,but only with the windows down. the arrodynamics (very little) causes a slite vacuum (I guess) in the cab and draws in air from wherever and of course it will be by the exhaust... go figure! I have a small rot spot and bad trunk seal. And no rear speakers just the holes.
bernie
Reply #11 on:
October 15, 2007, 05:28:56 PM »
Your exhaust tips aren't below the body line or not out the back far enough. I've had this problem on a 65 convertible, 66 convertible and a 69 shelby. Go buy pipes to extend the tail pipes and the fumes will go away.
mustangluver
Sr. Member
Mustang: 66 coupe 289
Daily driver: 2008 Hyundai Accent
Reply #12 on:
August 28, 2009, 09:36:13 PM »
your floor could be rotted as well. check the firewall, floor and the trunk
Gender:
Reply #13 on:
August 28, 2009, 10:10:56 PM »
This thread is like 4 years old. I haven't heard from these posters in several years.
mustangluver
Sr. Member
Reply #14 on:
August 28, 2009, 10:14:21 PM »
lol it gave me the lil warning. the world may never know wat he ended up doing however.
Pages:
1
Go Up
Forum
Technical forums
Topic:
Navigation
Used Cars for sale
Ford Mustang classifieds
Powered by
EzPortal
